Nepenthe1957 »
https://forums.nicoclub.com/nepenthe1957-u104258.html
Sun Jun 21, 2009 12:00 pm
The CVT in my 2009 Murano is misbehaving. No codes set and it wouldn't repeat at the dealer, thus it came back NTF. Here is the info I gave them.
********When it happens:I notice the problem most often when making a normal (non-aggressive, constant pressure/position of the pedal) launch from a stop on a street with a 35-40 MPH speed limit. Unfortunately it does not do this every time. I took the car out for 30 minutes last night and it did not happen once. On Sunday it happened on every launch for an hour.
Normal behavior:If one watches/listens to the RPM during such a launch, normally the engine starts at idle, climbs smoothly to perhaps 2200-2400 RPM, and smoothly backs down to the 1500 RPM range as the transmission “upshifts” and speed stabilizes at 40MPH.
Problem behavior:When it is misbehaving it starts at idle, but then the RPM swings high (around 3500 RPM). If I keep the gas pedal steady, the RPM will remain there and not “upshift” and back off as normal (hence my description of “slipping”), even at 40 MPH. If I wiggle (partially release and reapply) the gas pedal, the transmission reacts and the RPM drops down to the normal 1500 RPM range.
*******I have recently discovered that I can get it to recover from this situation by "double-tapping" the O/D off switch on the side of the shifter.
Any informed thoughts on the matter? Anyone else have this problem?
