I've been doing a lot of reading on the concept of "Hypermiling" to save MPG and one of the chief principles is to switch from D to N whenever possible to immediately drop your RPM's and use your momentum as long as possible; especially if you are on your way to a stop at a light of traffic. It works much better with a Manual, especially if you undershoot and have to go back in gear before stopping, but AT's can also use this to their advantage to save gas.matt_a wrote:When and why would you ever sit and idle in "N" with an automatic or CVT?
Exactly. I also can't help but think that it's a little hard on a car to be constantly shutting the engine off and restarting it.coxcj wrote:I'm not so sure about the wear and tear on the car. I used to drive a 5M jetta, and I did that all the time. The only concern I have is that the CVT has such a hard shift into gear from neutral, so I would think that it's not that good of an idea.
I'd like to see some test results to know how the CVT would do after prolonged activity like that. (at this point I'm not willing to subject my new baby to the challenge).
This won't work for you anyway. Hypermilers shut off their engines at highway speed (they're not talking about shutting down at red lights when you're safely stopped). They do this and then coast as much as possible while drifting behind semis. You can't do this with an automatic, and it can be very tricky with a manual. Most automatics can't be shut off and turned back on at that kind of speed without significant damage.snwbrdraw wrote:Once you get the hang of the Neutral Shift, they also recommend you shut your car off completely to further reduce gas consumption. Not sure I am going this far as the loss of power steering and brakes doesn't sit well with me.
When I drove stick, I could shut off the engine but retain my power steering and breaks as long as the accessories were on... You might could try that and see if it'd work on the V... mind, I only did this on the steep downhills when you'd be going for awhile, starting up is a strain on components too...snwbrdraw wrote:they also recommend you shut your car off completely to further reduce gas consumption. Not sure I am going this far as the loss of power steering and brakes doesn't sit well with me.
