See.. that's in line with what I have been seeing from other users.. and yes.. my commute is flat. I live in South Louisiana! (bout as flat as it gets!)srellim234 wrote:On relatively flat terrain 2400 rpm and 70 mph is about right for my '07 with CVT. At 65 mph the rpms run about 2300 or so. I'll check on rpms at 55 tomorrow when I run over to Covina and get back to you.
I'm not mechanic or even very knowledgeable about transmissions but it sounds like something is wrong if your cvt has to rev that high to maintain 70 mph provided your commute is fairly flat.
Cool.. I'm not looking to get 40 by any stretch of the imagination, but 30-32 would be nice! I had 98 Neon R/T with a 5 speed that I used to get 33 with. I figured something had to be wrong with it.Shad0wXCalibur wrote:2400-2500 RPM here at 70 mph with my CVT. It sorta sounds as if your CVT isn't locking in. Your dealership should get that fixed and then you should have no problem getting to 30 mpg if you're already getting 28-29. It's mostly not a "driving style" thing. Some cars of the same model just get better mileage than others. My old Neon with a 3-speed slushomatic got way better than the sticker mileage and I was not easy on it.
positive!srellim234 wrote:Obvious afterthought: are you sure your overdrive is on?
barchief wrote:Cool.. I'm not looking to get 40 by any stretch of the imagination, but 30-32 would be nice! I had 98 Neon R/T with a 5 speed that I used to get 33 with. I figured something had to be wrong with it.
33 is what I would get when I would be on an all highway mileage trip.. mixed driving I used to get about 27-28.Shad0wXCalibur wrote:barchief wrote:Cool.. I'm not looking to get 40 by any stretch of the imagination, but 30-32 would be nice! I had 98 Neon R/T with a 5 speed that I used to get 33 with. I figured something had to be wrong with it.
33 is really considering the trans in the R/T was designed for speed and not fuel economy.
Ya the CVT runs it at lower RPMS08versailles wrote:Not Fair!
Turning 2800rpms at 100km/h in 6th gear manual!![]()
Second refill coming shortly, stats to follow...
Sounds like someone didn't stick the needle on rightbarchief wrote: By the way.. I took it in on Monday, and they found something... my tach is reading 500 RPM's too fast.. It sits there on 500 even when the motor is off and I never noticed it before.
I guess my theory of the CVT running too high isn't causing my mileage issues.
I got about 13,000 miles on it so far, so I would hope that the break-in period is over.Shad0wXCalibur wrote:Sounds like someone didn't stick the needle on rightbarchief wrote: By the way.. I took it in on Monday, and they found something... my tach is reading 500 RPM's too fast.. It sits there on 500 even when the motor is off and I never noticed it before.
I guess my theory of the CVT running too high isn't causing my mileage issues.. But about your mileage, it may be that the engine is still breaking in. Sometimes it takes a lot of miles.
kvg wrote:do you have heavy wheels? sticky tires? run a/c? these could all have an effect?
and hot weather does it too.
