motoguy128 »
https://forums.nicoclub.com/motoguy128-u46857.html
Thu Jan 18, 2007 5:32 pm
I believe the CVT uses a special oil for lubrication and cooling of the belt drive mechanism. It may also move the CVT hydralically. When its cold, it might cause the belts to move sluggishly or the computer has programmed it not to shift until it starts to warm up.
I wouldn't worry too much about it. Most automatics also delay shifting when cold. My '04 Honda Accord used to hold 1st gear when it was cold. Shifting to to low of a gear can cause poor performance and lugging.
THe main reason the engine makes less pwoer when it's cold, is because it produces less power. A large protion of hte engine's power is going into heating the engine block, heads, fluids and trhansmission. SO instead of making maybe 20HP as you pull away, it might only make 15HP when it's very cold. 5HP are lost as heat. WHen the enging hot, the heat transfer losses are less and more energy.., goes into moving the piston. 5000watts, is almost 7HP, it's not hard to believe that the engine can absorb or lose that much heat as low temperatures when you consider there's 300+ lbs of metal and fluids with 30mph air blowing over it.
