only?!? is it me or is close to $600 pricey for a transmission flush and refill? even despite the fact that it's a V6 Altima etc etc... i'd expect that from a bimmer or benz but for an altima?? not coolhobiray wrote:I was told by a dealer today that my wife's coupe needed the cvt oil change at 30k mi. for only $589.99. What's the deal with this? Is this diy?
I'm close to 40k/km, I ask them how much for the CVT Fluid. They won't even tell me, instead they said it not necessary and that it's going to be very expensive. They went on about how CVT is this/that...hobiray wrote:I was told by a dealer today that my wife's coupe needed the cvt oil change at 30k mi. for only $589.99. What's the deal with this? Is this diy?
no, cvt fluid does not need to be changed at 30k, more like 80k-100k...also buy nissan NS-2 CVT fluid online and go have done at another dealer whenever you need a changehobiray wrote:I was told by a dealer today that my wife's coupe needed the cvt oil change at 30k mi. for only $589.99. What's the deal with this? Is this diy?
so how much fluid would it take for option 2?adidas2go wrote:Its not hard to drain the CVT transmission fluid. Their are a few ways of doing this.
Procedure 1
1. Drive your car for about 10 min.2. You leave the car running in park. 3. Disconnect the CVT fluid line coming from the radiator, going into the CVT. You will let this line drain into your bucket for disposal.4. Refill with new CVT fluid at CVT fluid charging pipe, with the engine running at idle speed.5. Refill until new CVT fluid comes out from CVT fluid cooler hose, you disconnected in step 3. 6. Reconnect everything, and your finished. Takes about 25 min, and 11 quarts of NS-2 Nissan CVT fluid.
Procedure 2
1. Remove drain plug from CVT oil pan. 2. Drain fluid3. Reinstall drain plug in oil pan4. Fill CVT with transmission fluid at the charging pipe 5. Drive CVT for 10 min6. Check fluid level. 7. Add fluid if necessary.
Hope this helps guys
Oh yeah. I definitely do not want any of the above people going anywhere near my expensive, highly advanced CVT.LinkNuc wrote:Yup, and if you don;t wanna do it yourself, Jiffylube, Meinike, and your Grandpap or dad will do it for less than a bill.
Your Titan doesn't have a CVT.LinkNuc wrote:Yup, and if you don;t wanna do it yourself, Jiffylube, Meinike, and your Grandpap or dad will do it for less than a bill.
Here's why you are getting ripped off....My Titan's 30K tune up cost me 149 bucks...and its a 4x4....seriously wtf kinda dealer do you go to?
Oh I know TX is a big state but if you can get to courtesy do it
BTW, I have a call into a good source on what it actually costs...I will post once I get reply
Modified by LinkNuc at 2:52 AM 1/11/2009
Motor oils are required to conform to a minimum set of viscosity standards - I don't think the CVT is held to that standard as of yet because of the proprietary nature of it right now.adidas2go wrote:I think its just like motor oils personally. All different brands, different viscosity, different chemical makeups. However, many of them are compatible with many different kinds of engines. I know there are not as many moving parts in the CVT as their are in an engine.
I don't think its the EXACT same chemical makeup as the NS-2 fluid, I think it may be better. Made for high heat situations, and less breakdown. Just as synthetic oil is better than conventional.
Also, Nissan isn't going to know whether or not you used a Nippon oil. Worst case scenario, your transmission starts acting up, and you replace the fluid with Nissan stuff, with the steps I stated earlier in the thread.
