http://www.nissanassist.com/web/CVT/veh ... hp?menu=11Nissan has extended the Nissan New Vehicle Limited Warranty for the Continuously Variable Transmission (CVT) to 10 years/120,000 miles (whichever occurs first) for CVT transmission repairs, replacement, and related towing on all 2003-2010 model year Nissan vehicles equipped with the CVT. The remainder of the powertrain warranty coverage for components other than the CVT transmission remains unchanged. All other warranty terms, limitations and conditions otherwise apply.
http://www.nissanassist.com/web/CVT/index.php?menu=8
riden3 wrote:I'm looking into getting a Certified Pre-Owned 2010 Nissan Rogue S with 50,000 miles on it. It's my first car, don't have anyone I can ask for help, and will be driving this thing on a few 800+ miles trips in the next few months so hoping you guys can help relieve my worries because I don't want to be stranded anywhere...
I read nothing but good reviews about this car but then I found one about the CVT issue and that seemed to open a can of worms. Considering I couldn't find to many negative reviews I'm hoping these CVT issues, although somewhat common, are isolated. It seems people recommend changing the CVT fluid every 30,000 miles or so and to also keep an eye on the temperatures of the fluid to make sure it's not over-heating.
If the car has been taken care of and I make sure to change the fluid every XXXX miles as required, only use factory fluid, only have it done by Nissan retailers, will I run into these CVT problems? Do they not happen if you take care of the car or is it just a crapshot.
I live in the Midwest/Colorado if the type of climate will matter. Thanks!
the car fax SHOULD (not always does) state if the car had a repair to that degree. regardless...riden3 wrote:One last question - is there anything I should look for when looking at the Rogue to see if it had any CTV problems, or any problems in general?
Why not ask the dealer for a printout of all warranty claims associated with your VIN? That should lead you down the path of knowing what the previous owner had problems with. Because a 2010 with 50K miles was under warranty during the entire (or almost depending when exactly he bought it) time the previous owner(s) had it, it would seem reasonable any problem was fixed under warranty.riden3 wrote:Thanks for the replies ImStricken and RogueOne! They really helped a lot. Sounds like I shouldn't have to worry with a 2010 and if anything does happened I'm double-covered from their extended warranty and the CPO.
if you tell them the symptoms they will know what it is. when you first schedule the appointment DEMAND that you will not pay for this service, since its transmission related, and common.kilogram wrote:I just had a rather disconcerting experience relevant to this.
Going up I70 out of Denver, got about 5 miles past Georgetown when the CVT started whining. A few minutes later it went into failsafe, wouldn't let the engine rev over 3000rpm and I couldn't go more than 40mph. Turned around and headed home and stopped at Beau Jo's for lunch to let it cool off (all the driving to that point was downhill anyway). Now it drives normally again, but I'm not looking forward to the dealer bending me over just to look at it. I'm only at 47k miles (still 13K away from the service interval for CVT fluid) and to me, it's pretty unacceptable for a car to have issues this early. I don't tow anything with it, nor do I drive it offroad anywhere. Not to mention I'm probably putting down about 20hp less than people at sea-level are due to the altitude.
My guess is that the dealer will tell me I need to flush the rubber band box and that it will not be covered under any sort of warranty. This honestly has me thinking about ditching this car.
topic moved to the correct thread.DTASFAB wrote:From the original post on this thread, it seems like proper maintenance can potentially stave off CVT troubles. As long as the fluid is filled to the correct level and it's not foamy, and the coolant is mixed to the correct concentration for protection at -25 degrees, will the transmission be reliable even on long trips?
Yeah, that ship sailed a long time ago. Forget the acceleration problems that began in 2002 when they took out the cable connecting the gas pedal to the throttle body and went to drive-by-wire. The problems started with oil sludge in 1997.ImStricken wrote:if you are expecting quality that your two camry's have = you wont find it, even on the newer camry's! lol
My initial thoughts are that the exterior colour of the vehicle will have little to no effect on the temperature the CVT runs at. The CVT receives air from underneath the vehicle to help cool it naturally and that should take care of any issues relating to external heat (unless you just run it in 100 degree heat for hours on end I guess).DTASFAB wrote:So my main question is, on a 2013 Rogue, will proper maintenance and a white exterior keep me safe from CVT problems, or am I doomed before I've even bought the vehicle? Please help!
I belive what you are noticing is the effect of engine braking - it's where you use the drivetrain to slow your vehicle down versus using the brakes. Putting it in neutral disengages the drivetrain (coasting).DTASFAB wrote:Picked up a brand new 2013 Rogue SV with premium package over the weekend in frosted steel with black cloth interior. That's the paint color that changes color like a chameleon - blue in the bright sun and silver looking when cloudy. Depending on the amount of sunlight and any shadows in the area, one part of the vehicle will look one color while another area of the vehicle simultaneously appears to be another color. I've never seen anything like it, but it's awesome. My OTD price was almost $1400 less than MSRP as configured. No CVT whine after 255 miles driven! Seems like a nice friendly little truck so far. And the radio is nice.
I've noticed one of the things the CVT haters complain about, which is that sometimes when I'm in gear rolling down a hill at about 40 mph approaching a red light at the bottom of the hill and my foot gently applying the brake not really to stop but to prevent the vehicle from gaining speed as I go down the hill, the tach shows the engine is running at 2500-2800 rpm. There's absolutely no reason for it to be revving that high in that situation. The cabin is insulated enough that it doesn't create any excess road noise, and it's probably not contributing any excess wear and tear, but it can't be good for fuel economy. This is with OD on and sport mode off. This is probably why the MPG rating is about 4 lower than the CX-5.
On another trip down that same hill, I slid the shifter into neutral and did a true coast, and of course, the RPMs went down under 1000, since the transmission was behaving as if the car was stopped and idling.
Every automatic can be different as to whether they use engine braking. Nissan's CVT's do use engine braking when going downhill and in some models (I will not say all as I do not know about all their models) the engine braking feature can be turned off by the dealer.DTASFAB wrote:In my experience with ordinary 4-speed automatics, the RPMs will hover at 1000 or below when moving down a hill in 4th gear at 40mph with a slight application of the brake to maintain speed. Sometimes, this engine speed can be even less than the idle speed when the drivetrain is disengaged in neutral or park, depending on the vehicle. Engine braking doesn't exist in the higher gears, or it exists to a very minimal degree. Applying the brakes harder to reduce speed does not result in an automatic downshift. It's not going to downshift unless and until I accelerate again or downshift myself to achieve engine braking.
With the CVT, engine braking can happen at any speed if the transmission decides it's going to help me come to a stop at the bottom of the hill. I guess it's a case of pick your poison. The CVT's proclivity to use engine braking may help extend the life of my brake pads, but it's going to cost on fuel economy. My point is I'd rather have more ability to control engine braking, similar to a traditional transmission.
That's interesting. Since the only choices in the Rogue are L and D, rather than L/2/D3/D4 in an old Honda automatic or L/2/D/OD OFF/OD ON in an old Toyota automatic (OD on or off is essentially the same as differentiating between D3 and D4 in the Honda), I think I'd rather have automatic engine braking in the Rogue (as it's currently programmed), since having the feature turned off would reduce the driver's ability to engage engine braking on the shifter when it's actually needed. If I'm going down a hill in the snow at 35 and I hit some black ice and go into a skid, I want as much engine braking as possible. Such a loss of control might only happen once every 40,000 miles driven, but preventing that one disaster is worth the annoyance.TrevorK wrote:in some models (I will not say all as I do not know about all their models) the engine braking feature can be turned off by the dealer.
I have to ask though - why would you want more shifting options? The OD button takes care of issues related to towing, so that's covered. Otherwise what realistic situation would you encounter where you need other options? Paddle shifters seem silly in an automatic as a computer shifting will always beat a human shifting.DTASFAB wrote:In other words, the Rogue's shifter should have more available options!!! With no paddle shifters available on the 2013 Rogue, the only controls I have are OD on/off and sport mode. For the little I've tested them out so far, sport mode seems to do very little or nothing, but keep in mind I'm trying to be as gentle as possible during the break-in period, so maybe I'll notice something different later on. Turning off OD makes my RPMs go way up regardless of wheel speed. It also unleashes a lot more power, and presumably burns more fuel.
I suppose a component of this is that old habits die hard. In an older Toyota, I can get the transmission to upshift whenever I want it to by letting up on the accelerator just enough at exactly the right moment and for a precise amount of time. I can get it to downshift whenever I want by moving the shifter to a lower gear. It's not the same as a stick because there's always going to be a measurable loss of power in the automatic compared to the same car with a stick, but otherwise, I can control and manipulate my automatic transmission as if it were a manual.TrevorK wrote:I have to ask though - why would you want more shifting options? The OD button takes care of issues related to towing, so that's covered. Otherwise what realistic situation would you encounter where you need other options? Paddle shifters seem silly in an automatic as a computer shifting will always beat a human shifting.
