casperfun wrote:I read the following online about the Versa and it seems to pertain to my Rogue too:
Nissan Versa CVT Coasting Ability
Quoted from Mudd from Nissasnversa.org forums
Quote:
Made a chance discovery today, at least on my vehicle. Have the 2007 SL with CVT.
I've noticed that when going about 60mph or so and let off, the motor holds rpm and I can feel the drag as the speed decreases. At about 20, the drag stops and the vehicle feels as if it's free-wheeling. Good, that helps with the fuel economy. Was wondering whey Nissan didn't do a little better and let it free-wheel at a higher speed. Would sure be a fuel saver. Had a Buick Rivera that did this at any speed.
By chance at a speed of about 40mph I let off and again just tapped the gas pedal. Surprise the rpm dropped to 1100 and continued to coast at 40 as there was a slight drop in the road. I did this again (tap) at higher speeds but could not get the same result.
So it seems on my car at least, if one taps the pedal at 40mph or less after removing foot it will go into free-wheeling mode. Maybe my vehicle has a Fluke? Don't know but I like this way. I'm going to mention this to the shop man at my next visit.
Would like to hear from anyone else that notices that on their Versa.
sweet! so it acts like N when the user lifts his foot off the gas... this could be the car for me I like how if you apply light throttle it will be in a deadband wannabe mode.... sounds promising!!!
And from what I read about the CVT ride, its almost hybrid like, when coasting you can't hear the engine. There were a few edmund users posting 40 ish tanks and their engines haven't even broken in yet! So I think this car looks promising since its 5000 cheaper (including the hybrid tax refund) than a new hybrid car.
OK, I had the possibility to do some experimenting yesterday, but not a lot as my drive is only 5 kms to get my daughter at daycare and bring her safely at home.
At 3 occasions after the car was enough warm to allow cutoff fuel while coasting to a stop, I was able to get 0 LPH and 0 LHK on the scangauge (fuel cut off when lifting my foot of the gas).
Even with barely not applying gas again (a few mm on the gas pedal), the scangauge always showed some fuel going back in the engine. And I was always above 20 mph so the torque converter was fully engaged.
Conclusion: Sorry guys, no free wheeling possible on the Rogue (I believe this is the same for the Versa listed above, but he will only know if he has a scangauge plugged to his car).
If you lift your foot off the gas, you will get some engine braking (either you find it moderate or not is your opinion on the matter), and if you apply back some pressure on the gas pedal, you will get some fuel burning.
