adidas2go »
https://forums.nicoclub.com/adidas2go-u78832.html
Thu Sep 11, 2008 11:32 pm
Its how direct the power transfer from the engine to the wheels are. For example, gear ratio 1 is 2.371:1. So, the engine makes 2.371 revolutions for every revolution of the transmission’s output.
Also factored is in the final gear reduction ratio. The CVT a/c's is, 5.173:1. This means that for every 5.173 revolutions of the transmission’s output, the wheels make one revolution. The differential ratio multiplies with the transmission ratio, so in 1st gear, the engine makes 12.265 revolutions for every revolution of the wheels.
In any gear ratio lower than 1:1 (such as 4-6 in the a/c) the car is in an overdrive gear. This means the output of the transmission is revolving faster than the engine. The equation from above works on these ratios as well.
V6 CVT A/C's drive ratios
gear 1 = 12.265gear 2 = 7.914gear 3 = 5.742gear 4 = 4.448gear 5 = 3.569gear 6 = 2.270
V6 6 speed A/C drive ratios
gear 1 = 13.031gear 2 = 8.059gear 3 = 5.753gear 4 = 4.360gear 5 = 3.343gear 6 = 2.603
