CVT Fluid question every changed it yourself?
All things Altima Coupe.
nissansp
Car: 2008 altima 3.5se
Ok so I like to do maintanance myself when possible. You know what gets done and doesnt get done that way. Has anyone ever change the CVT fluid themselves if so how did it go?? would u recomend it?
any good write up you could direct me to..
Id love to change coolent and cvt before winter..
QR25DE
Car: 2009 Altima Coupe 2.5L 6MT Turbo
From Adidas2Go:
Its not hard to drain the CVT transmission fluid. Their are a few ways of doing this.
Procedure 1
1. Drive your car for about 10 min.
2. You leave the car running in park.
3. Disconnect the CVT fluid line coming from the radiator, going into the CVT. You will let this line drain into your bucket for disposal.
4. Refill with new CVT fluid at CVT fluid charging pipe, with the engine running at idle speed.
5. Refill until new CVT fluid comes out from CVT fluid cooler hose, you disconnected in step 3.
6. Reconnect everything, and your finished. Takes about 25 min, and 11 quarts of NS-2 Nissan CVT fluid.
Procedure 2
1. Remove drain plug from CVT oil pan.
2. Drain fluid
3. Reinstall drain plug in oil pan
4. Fill CVT with transmission fluid at the charging pipe
5. Drive CVT for 10 min
6. Check fluid level.
7. Add fluid if necessary.
Hope this helps guys
cvt-oil-change-t395369.html
and
http://www.nicoclub.com/FSM/Altima/2008/ma.pdf
