DG65 wrote:MODIS not Midas. Similar to the ODB II.
I lol'd and no one else thought that was funny....ahh that is a true sign you are a geek.
I really do not know what year the degradation count became available over standard or even Modis communication protocols. Many devices do not communicate well over Nissans LAN, I would assume is any device were to be able to get into that data it would be that one.
Here is the 07 manual excerpt (about 45 minutes later)
“CVTF DETERIORATION DATE”
More than 210000:
It is necessary to change CVT fluid.
Less than 210000:
It is not necessary to change CVT fluid.
in the CVT section it is page 59 (for 07).
http://www.nicoclub.com/FSM/murano/2007 ... no/cvt.pdf
Buckshot wrote:There is a count in the trans control unit that they say should be looked at per Nissan training but 60k is great use only Nissan VCR fluid and I think it will take about 5 qt
I had a whole thing about checking the rate adding to the reason to take it to the dealer written but I could not for the life of me find where in the owners manual, or service manual mentioned specifics in any of the headlines. It is in the work support section if you have access to sub-system work support features...than yes you should have access to it but there are no generic scan tool directions so I am not very confident.
