marlin29311 »
https://forums.nicoclub.com/marlin29311-u97240.html
Tue Mar 30, 2010 5:00 am
The CVT fluid does NOT need to be changed at 30k. The fluid is actually designed to withstand going over 100k miles (under ideal conditions...).
The Nissan tech's have a diagnostic tool that can be plugged into the transmission which yields a "degridation" number - aka, whether or not it needs to be changed.
At 30k, the service department should do the reading, and if the fluid is beyond the threshold (I don't have the numbers right now), it should be changed. Otherwise, you should wait again until around 45k to do the diagnostic again. If still ok, then do a certian change at 60k.
