Niklaus1024 »
https://forums.nicoclub.com/niklaus1024-u244901.html
Sun Jan 18, 2015 2:10 am
well come to find out that is is not the half axle that is leaking is actually the oil cooler housing itself; Nissan wants way to much to replace it of course. That is the least of my concerns currently; now I am having some acceleration issues; I recently replaced my spark plugs because of this issue, but Nissan also says that my fuel injectors need to be cleaned due to miles etc.. When I replaced my spark plugs the lag or sluggish response/or pause before acceleration stopped temporarily but has now come back and seems to be worse then before. When I initially start my car for the first time after sitting a while or overnight the car accelerates normally but if I come to an abrupt stop and then accelerate from a stop the pause is somewhere around 2-4 seconds maybe longer; also when I've been driving a good amount of distance the problem seems to be then as well....any suggestions or advice will be appreciated.
