marlin29311 »
https://forums.nicoclub.com/marlin29311-u97240.html
Thu Mar 19, 2009 1:40 am
Most people say that anti-freeze is something that should be changed every year or every other year.
CVT fluid costs a boat load to have changed - before having it changed, ask your dealer to run a diagnostic on the fluid, and they can tell you if it needs changing - the fluid was designed to go over 75000 miles, but some people's could break down faster depending on the use of the car, conditions, etc...changing the fluid is several hundred dollars at the dealer because of the labor and the fact that the fluid is anywhere between 10-20 a quart.
