I messed with the switch and did get it to momentarily work.
I had to take it out and clean it a 3 or 4 year's ago because car was acting wierd (probably like this lol)
This time I'll replace.
I remember last time the two circuits agreed, not were inverted. Both said on or off depending on state.
One other oddity, often the first run of the day it feels like on reverse it just isn't.... Idk how to explain. It's kinda like you need to give it more gas than you should to move but I don't feel the car shifting upwards like would happen if the parking brake was a little stuck (plus you feel it let go when hit the pedal)
Then going forward it's a little of the same until maybe 5mph is broken and it feels like it clocks into gear kinda sorta.
I did find one other post with a similar comment but there wasn't a resolution. I'm wondering if it's the rear diff. It seemed like the one front wheel was not spinning the speed it should as Wifie backed out a few days ago, it's a rock parking spot. But TCS light isn't coming on during those.
This is a much longer running issue which uh... Maybe there's some connection?
https://www.nissanclub.com/threads/loud ... up.267484/
Saw another comment talking more like I am here but not finding it yet.
As for lowish pressure, could It be explained by maybe being under filled when I changed the fluid?
