If you do a search for "altima coupe transmission cooler" you'll come up with some info that could help you out on this. There are alot of kits out there that are "universal" kits that could be fitted to any car (provided you buy one and have enough room to install it. B&M supercoolers get used alot. Basically you need to find a location for one and then just modify how the piping for the fluids gets run to get the benefits.IBCoupe wrote:Is there an application for 3.5's?
Mine's in front of my intercooler. Hard to get pics of it since it's crammed in there but it does the job well!If there are any turbo'd cvt readers reading this, please post up where your transmission cooler is placed please. Pics would be great.
Ranga14 wrote:Mine's in front of my intercooler. Hard to get pics of it since it's crammed in there but it does the job well!If there are any turbo'd cvt readers reading this, please post up where your transmission cooler is placed please. Pics would be great.
This is very true. Those hard launches at a high PSI would be the killer.Zerep wrote:it fits but with modification since it is a universal part but we i dont know if in the end torque failure will over come heat failure
ifuxwituz wrote:i have a 2009 maxima which only comes in a CVT and i have installed a HAYDEN TRANSMISSION COOLER to it i purchased from summit racing i installed the cooler when i had a little under 50,000 miles now i have a little over 120,000 with no CVT issues and the cooler was super easy to install.
all you really have to do is remove the return line (that goes back into the pump which in return goes back into the trans) and connect that line to the cooler then the exit line goes to the pump. i could supply a diagram for those who dont understand. you could also contact me on facebook my email is [email protected]
