CVT app for Android
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
Apologies if already discussed.
Anybody with any impression on this?
Good, bad, nice, helpful? Etc.
CVTz50 is the name of this app.
CVT diagnostics with ELM327 for Nissan-based vehicles
To verify CVTz50 compatibility with your ELM327 adapter and vehicle, please use CVTz50 DEMO: https://play.google.com/store/apps/deta ... cvtz50demo
Main features
- Read and clear CVT diagnostic trouble codes
- Read and clear engine diagnostic trouble codes
- Read and clear CVT fluid deterioration
- Adjust engine braking level
- Adjust Idle RPM and Ignition timing; Idle air volume learning (only for Murano Z50 and related vehicles produced before 2010)
- CVT Data Monitor: real-time monitoring of CVT parameters: temperature, pressures, trouble codes, gear ratios, step motor position, torque converter lockup
- Collecting and displaying monthly statistics on temperature conditions, pressures, milage, fluid deterioration
- Supports Nissan Murano Z50/Z51, partial support of other vehicles equipped with Jatco CVT – Nissan Teana, X-Trail, Qashqai, Juke, Note, Tiida, Sentra, Wingroad; Mitsubishi Outlander, Lancer; Renault Koleos and others
Hardware requirements:
- Phone or tablet running Android 4.2+
- Bluetooth or WiFi adapter ELM327 revision 1.5 or lower (functionality might be significantly limited if used with not genuine adapters of revision 2.0+) :woot:
phmichel
Car: 2013 Nissan Rogue S AWD
2017 Nissan Quest SV
Been using the full version ($4.99) for about a month. Now FINALLY able to read actual CVT temp plus fluid condition and a host of other valuable data. You can also turn the engine braking function on and off with the full version.
TheScarletRogue
Car: 2015 Nissan Rogue, Cayenne red
Can anyone recommend a good, budget friendly, genuine ELM327 adapter? I got one on line for like $5 and it doesn't seem to want to work with the app and I am assuming that it is because it is a knock off
chunt5
Car: 2018 Nissan Rogue SV
TheScarletRogue wrote:
Thu Mar 29, 2018 5:55 am
I have been using this APP for about 3 months. I am also using the 4.99 version. You must use an ELM 327 adapter version 1.5. Versions 2.0 and above will NOT work. I purchased mine on ebay from china for less than $10. Sometimes it will not connect the first time. I correct this by disabling and re enabling blue tooth on my phone.
Return to “Rogue Forum”
