Check out the Rogue forum. That is usually an indication that your transmission has to be replaced. Have you ever changed the trans fluid? How many miles on the car?NadesR wrote:Nope it is not sigh....thanks for the response.
Didn't know what a tiida latio was until I just googled it. Look at other forums here where the car uses a CVT.NadesR wrote:Yep I changed the trans fluid, the mechanic says that I may have to do a proper flush, other wise the car runs smoothly and works fine.....the mileage is about 59000 km....
After it warms up the noise goes away so it's a little odd. Will check the forum.
Thanks!
