IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Sat May 20, 2006 5:58 am
the drivers side is cake. the pass side is a SOB.
with air tools and a lift, i did the drivers side real quick, but the pass side was a pain. its difficult to get to the bolts on the center carrier, and removing the bearing from the carrier is a pain.
also, the rebuilt axle came with paint on the outer bearing surface. i should have wirebrushed the paint off, but i just used the bolts to pull the bearing into the carrier in a cross pattern. its gonna suck if i have to replace the pass side again.
im not sure if i would attempt to do the axles without air assistance. alot of cursing will be involved.
