cv joint
gophrsplatter
everytime i turn my wheel hard to the right i get this screeching noise that hurts my ear and the steering wheel won't turn anymore and is pushed back towards the left...is this a cv problem?? how much would i expect a shop to fix it for? maybe this was the problem i have had with my wheel shaking at 65-70mph also the car is a 96 240sx. thx
NISTECH
maybe its just a loose power steering belt?
gophrsplatter
is the power steering belt on the first groove from the crank pulley...or is that the a/c belt?
NISTECH
It is the belt that goes to your p/s pump..I dont know the orientation on your vehicle specifically. but the pump is mounted on top on the passenger side of the valve cover. the pump itself is your adjuster. loosen the pivot bolt throuh the pulley hole. then loosen the adjuster lock bolt from the front on the bottom. then tighten the adjust bolt from the passenger side of the pump at the bottom[ this is attached to the adjuster lock bolt block] then resecure every thing and recheck.
