CV Half Shaft
Bori83
Car: Coupe 3.5 MT
Anyone know of any place where i can order the Half Shafts for an 08 A/C? Not the dealership. Their prices are :bs: . I have a clicking noise coming from the front everytime I make a turn. I cant find them anywhere.
Thanks
boystar22
Car: 2008 Nissan Altima Coupe 2.5S
Are you sure the clicking is coming from the CV Joint? Lots of people have had and fixed the clicking sound (me included) by turning the cotter pin on on the wheel hub around and reinserting it the other way. For some reason it clicks every revolution under certain circumstances.
BigDankCloud
Car: 08 Altima Coupe 3.5SE
Jeeeeebus thats what has been making that clicking? I've always assumed I did something wrong after I changed my break pads out...
Welp, something else to do once i get the eibach replacement springs
Bori83
Car: Coupe 3.5 MT
boystar22 wrote:Are you sure the clicking is coming from the CV Joint? Lots of people have had and fixed the clicking sound (me included) by turning the cotter pin on on the wheel hub around and reinserting it the other way. For some reason it clicks every revolution under certain circumstances.
Boystar,
That is a good and helpful information. I wasnt thinking about that. I have BC coilover and its pretty low. I was assuming it was that b/c i spit the grease out the boots. The mindbogoling issue is, the boots are not torn. They all seem fine, the grease is coming out through the shaft seal. :wtf2:. Im lost Imma try your info first though, thanks alot for the help.
Mike
boystar22
Bori83 wrote: Boystar,
Mike
It may not fix your problem but it's an easy and probably free thing to try out. I know the pin clicks once per revolution of the wheel, but i could only hear mine while turning too. You may have to replace the pin if the clicking has sheared the head off, but they are cheap at the hardware store. Mine was still good so just turning it around fixed it. I had to replace the cv boots on my last car and it was a pain in the butt, the AWD didn't make it any easier having 8 boots total.
