SixGuns »
https://forums.nicoclub.com/sixguns-u95290.html
Sat Jan 17, 2009 9:08 am
So when you say a spacer between the diff and the cv, you're talking disassemble the joint, remove the race/bearings and place a spacer behind the race, on the diff side, but actually inside the cup? Guess that would work...maybe do the same on the hub side, just to eliminate the risk of mismatching weak points...And where are these 3" longer-than-stock half-shafts at? I checked Total Chaos, but they don't stock anything...are we talking Frontier/Xterra shafts? Same spline count/diameter? If that's all that's available, I'll just go with the 3" and give the rig a Baja look...could be worse...Actually, after inspecting the front end of this thing pretty thoroughly with a local 4x4 shop, a coilover conversion and A arm installation should be pretty straight forward...just gotta make a drop bracket for the steering and sway bar...and of course, the extended A arms and mounting stuff...and the frame sleeves. Should be a good time, but F-O-A (check them out, nice stuff, not too expensive) told me that I'd be waiting 2-3 weeks for coilover delivery, so I need to get my measurements right on pretty quick here so I can order them...not letting my truck sit for 3 weeks....
