miamiheat3332 »
https://forums.nicoclub.com/miamiheat3332-u103568.html
Wed Aug 08, 2012 7:13 pm
The lift puts alot of stress on the cv joints and the angle they are at.
It is reccommended by people who have done the lift on our r50s to get manual locking hubs, that way the cv joints arent engaged when you are in normal 2wd driving.
The downside is, when you want to switch to 4wd, you have to get out of the car and turn the hubs, then it will engage, or you can leave them engaged, but then its just doing the same thing it was with the stock automatic ones.
It isnt all that bad, most of the year you only need 2wd, if its snowing out or something (i dont know where you live, so you may just keep them engaged when your wheeling), just leave them engaged for the day, cause you will be switching from 2wd-4wd alot or when your offroading.
Edit: by the way i think the hubs they get are made by a company called Warn and i think they cost around 100-150$ not sure.
Also the other reason they probably ripped within 2 weeks, is cause they were already years old and a bunch of mileage on them, already worn, then you put the extra stress with the lift and thats what caused it.
