Meantime »
https://forums.nicoclub.com/meantime-u7126.html
Wed Jun 04, 2003 5:35 pm
Get underneath the rear of the car and look towards each rear wheel hub, you will see an accordion-style rubber boot. If it is intact, and doesn't appear to be leaking, then chances are it's fine. If it's broken or you see grease emerging from it, then it's going south and needs to be replaced.
As for bearings, that involves removing the rear hubs. When you look at the bearings, they should be well greased and not have metallic flakes floating about. As I said before, I don't think you have a bearing problem, a bad wheel bearing lets itself be known pretty easily, in my experience.
To adjust the handbrake, pull it up...underneath the plastic boot, there is a small hole (facing towards the engine). In that hole there's a small hex nut that adjusts the handbrake travel. The manual specifies 6-8 clicks travel is normal. If you have more or less average clicks than that, turn the nut until you're within that range.
I believe mine has too many (like 12-14 clicks) so I need to adjust mine down.
