I'd have to take the hubs off tho right? I dont have the proper tools to take off the hubs =/AZhitman wrote:Why cut it?
It comes off in one piece, you know....
to get clearance so that I can hammer in the new ones from the back...AZhitman wrote:Booooo.
Yep. But why cut the dust shield just to put in longer studs?
yess...AZhitman wrote:Adrian, do I need to teach you how to put in new studs?
It doesn't sound good. It looks like splines on the hub got messed up and unable to hold the stud. I rather use thread lock or do it dry, not grease. You should remove the stud and inspect hub and see any splines left there. Worst case, you might have to replace the hub???adrians_s13 wrote:lets just say, its not easy taking a lug nut off when the stud is spinning freely with the wheel still on.
the thing is, @ 120lbs, I'd be afraid to strip the nuts, or even the studs.94_240sx wrote:
When you torque, I think the spec was something like 120lb. It was in the manual that came with Nismo studs, so I used washers and torqued down.
hey thanks for the linkKFL wrote:It's more 70-80lbs i'm pretty sure for torque it down. Find some OEM lugnuts I bought a 4pk of open ended from local autozone deal. Very bad 2 got hot and the threads started to come undone. Ended up messing two studs slight up but fixed them. I cheated and bought a new air gun and bam did the fronts in under 5minutes flat. Here's a local write-up pretty decent http://www.importfanatix.com/F...=1750
hmm... what if instead of getting new hubs, I just weld them in? do you recommend that? or should I just go to the junk yard and find some hubs? =/AZhitman wrote:Hubs are a WEAR ITEM, contrary to popular belief. Don't think you can just pop studs in and out like it's nothing....
