nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Fri Aug 31, 2007 6:16 am
It's still the RWD engine and has far more relation to the RWD DET, which is the section this should be in (or 240 Technical). Furthermore, FWD engines came in DET form too, so this isn't just a DE section, it's a FWD SR section - period.
No need to double post.
Regardless, an engine is an engine, so here's my input:
It can't be the exhaust. Why would an exhaust that's MORE open cause backfiring? You don't have a second O2 sensor either, so it's not that. You may notice it more now because your exhaust is louder.
TPS and plugs are a good place to start for sure. I'd also check the MAF.
