Romanuts wrote:The pictures are no good, but it does look like that is the main harness plug that the coil pack sub harness connects to. if im looking at it right, from the pic its upside down so that yellow wire is coming from the lower corner so it should be the wire that connects to the first cylinder coilpack but not the signal wire but the wire that tells the ecu it has fired. so your car should run but u do need that wire hooked up. Take better pics so that we can track it down.
yeah i know the pics suck... but if you look at the first one you can see the yellow wire is cut.... it was wraped up with tape untill i pulled it apart and found it. and yes it is the main harness that plugs into the coil pack sub harness. ill get some more pics tom... thanks for the help guys.
