cut up ignition switch harness??
NFixed85
Car: 1990 240sx
Ok Ive got a 1993 240sx coupe the switch harness has be cut up to where it could be repaired but I currently own a 90 240sx HB. I was thinking about taking the dash harness out of it since I know its good and the body is rough. If I did would i have to switch out the whole engine bay harness ? and the 90 HB has a kade swap what would be the best thing to do?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
You do know the ignition switch harness unplugs right? Just buy a new switch...... It will come with the harness and plug.
NFixed85
Car: 1990 240sx
no its on the main harness the the tumbler and harness connect to i could probably solder some new wire together but I may have to repin the engine harness and i dont have a diagram for it
compactfean
daily
Download the fsm from here for both years and they both have wiring diagrams. Me personally, id repair it.
NFixed85
Car: 1990 240sx
ok Ill do that, but I also notice that this car had plug ins for drop resistor do I need that be for I start swapping my engine/transmission the ecu was a late 90's kade when when it would be considered a 91 car.
