InsanityInc »
https://forums.nicoclub.com/insanityinc-u19073.html
Sat Jan 28, 2006 8:16 am
I'd like to make a correction to this:
Quote »Believe it or not, there is a good amount of engineering that goes into a spring. [/quote]Not exactly. A good amount of engineering SHOULD go into a spring, but rarely does. This is largely because of the consumer, however. See, a drop should be engineered with the suspension geometry of the car in mind, and the spring rate also needs to be relative to this drop and the damping of the shocks.
However, if you think you're going to magically get all that by buying a set of 100 dollar tien springs, you're dead wrong. 99.9% of aftermarket springs lower more than an ideal amount and also have a much lower spring rate than is ideal for that drop, which will make the car handle like crap.
But of course since people who slam their cars for looks are posers who will never see a track in their life, they get the false impression that their car handles better by driving around town at 4/10ths.
Man, I hate people.
