cut springs....cani use washers ...?
volcomskater773
Car: S14
ok long story but i ended up with a set of agx's and some cut tein stech's, heres the problem. because of the previous owner cutting the spring a little under a inch off .the driver side sits a little higher than the pass. my question is can i use washers between the strut and the strut tower to level it out? only reason i care is the horrid pull my car has to the passenger side...saving for a new set of springs so please dont say " why dont you just get some new ones" theres an event this tuesday and im kinda in a rush.
no ps makes this a horrid problem at the track, thanks for any answers.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
why not cut them so there equal?
Nissan2367
Or why not just buy new springs... cut springs will ride and opperate like crap!
volcomskater773
Car: S14
well its good to know that some people dont read the post fully befor posting, "event on tuesday. dont have time to get new ones"if cutting isnt a option, is it ok to use washers
Azrial
Car: 93 240sx vert, 1990 pignose hatchback roller
I would cut them to equal like sullivan said or you could go buy a spring spacer and shove in there. You can try washers if you really want to. I wouldn't recommend it but it may work.
dc1984
Car: 93 240sx/98 180sx blacktop sr20det :RIP/ 93 jeep grand cherokee
i agree, especially if u are going to be tracking it like that, not too sure how safe some washers would be.
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
i wouldn't use the washers. its going to be unsafe to use on the track. that S*it will snap on you... don't want to hurt yourself muchless your ride.
nekoabandoned
Car: s13 silvia
cutting seems like the best option, i spot welded the bottom of the springs to the strut so they wouldnt shimmy off during runs. anyone know a ruff idea about how much you cut equals height? probably worded that wrong but i think you get the idea
PHeller
Car: 1998 Ford ZX2 (wrecked) now 1989 Coupe
post some pics...i wanna see what cut Tiens look like (on the car).
Nissan2367
I was not saying buy them before the event but if you do some hack job like citting the others or buying "washers" you will never fix it then it will be half a**!
handinpants
Car: 240sx fast... powered by mice on a wheel.
if i were you i would shell out the dough for some new springs, because cut springs can fail at any time, its a problem waiting to happen, besides springs are only about $140
SullivanRacing06
buy new springs
