cut out s13 front fender whells?
nightsleek240coupe
Car: 1990 nissan 240sx coupe
look at this guy's setup. he did it to not rub or tub. safe or not?,what do you guy's think?i will be doing it to my chassis if it gets good feedback so iwon't have to buy tubs.
breaker77
im pretty sure hes gonna weld some new metal in there soon.
leaving it open would probably not be the wisest of ideas.
it would get dirty, weaken the already jello front end, probably cut your tire up if you slammed a hard bump and it rubbed.
ZOMG.SR20
Car: 1990 s13
bad idea you may as well tub it
MastaYu
Car: 92 Nissan 240SX SE HB
he wil complete it
nightsleek240coupe
this car was completed and entered in d1 miami with the cut whells.
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
looks like i got myself an answer to my new wheel clearance issues....
keith0486
but thats a track car thats a different story. i can see having cut wheel wells on a track car only for the fact they don't see many big bumps but for a street car i would say its got bad new all over it.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Id rather use a sledge hammer and pound the s*** out of that until it cleared, Given it wouldnt look that great but it would clear and wouldnt be Huge gapping holes and give a less ridgid front end, Id either tub or pound them...
mrgreeneyes
Car: ///M5
keith0486 wrote:but thats a track car thats a different story. i can see having cut wheel wells on a track car only for the fact they don't see many big bumps but for a street car i would say its got bad new all over it.
um. look at my parts list. its a track car, for all intents and purposes. i dont drive on the moon w/ craters in my path, vertical clearance isnt the issue in discussion.
i need to fully assess this tomorrow after some heavy massaging via BFH.
nightsleek240coupe
the s13 fender whells have no stuctural support to the s13 chasiss. so cutting them out is no problem.
Gabes13
Car: rb20det s13
resale value would go down
moulton712
Car: coupe, hatch, both s13s
that is a pretty unsafe idea. my last track car cracked on both sides of the strut tower. so there is needed reinforcement there.
also you have to think that's going to hurt performance in the long run. it's so close to the suspension that i bet you'll loose performance out of the expensive setup.
but on another note, i think though this person probably had some push issues so he made the front end unstiff. he could have 1) lowered front tire pressure, 2) changed spring rate and sway bar, 3) adjusted coilovers (lower front, raise rear) i donno, maybe light weight reduction stage 5?
