Cut hose (picture) Easy fix?
XtremeHKS
The intake manifold to valve cover hose has been cut, reason unknown. Is it an easy fix?
f s t caz
Car: VG30ET D21 Extended Cab Pickup
thats just the pcv line. you could probably run to pepboys and find the right diameter hose and make it work. won't look as nice, but would work.
rico05
Car: 1992 RMS13 w/ CA18DET
Just a note: My motorset came with that hose cut as well. Odd...
XtremeHKS
rico05 wrote:Just a note: My motorset came with that hose cut as well. Odd...
where did you find a new one at? Yeah and it is weird why they would cut that hose...
rico05
I am still looking, but may have found one.
Notchbackca
Car: guess...
the best fix would be to not have it go into the intake manifold at all... mine doesn't :|
engines don't like to eat thier own poop...
rico05
What did you do with it? Catch can I assume?
USDM_OneVia
Car: Racing
5/8 inch heater hose does the trick. About 4 bucks for 6 feet of it.
Joe
240 Trainee
Ok, why can't you just put breather filters on the valve cover? just a question, I was thinking about doing that, can't see any catastrophic results happening.
minutericesentra
Car: 96 Z32, 06 R51
I'm customizing my valve covers so there's only one fitting, that's going to a catch can with a breather on it, I hate hoses and crap going all over the place, oil in the intake, failing PCV valves...
Spectre_240sx
Car: 1990 240sx SE
Breathers seem to be a pretty contraversial subject. I know they're technically illegal, but does anyone have any solid information on whether they will hurt / help the engine?
Nismo1182
Car: Z06
All it does is pull air out of the crank case which the vaccumm from the intake helps out A LOT.
