Cut harness, need help on wires! w/ Pic! :(
StylezTA
Car: 2002 Trans Am
With my swap i got the normal (it seems) cut harness that was suppose to be uncut. I obviously know the maf but there is a plug that looks like it would go to the speed sensor.... but i already got that plugged in. next are those 5 wires, green, red, white, yellow, and blue wires all solid in color. harness was obviously cut. they come out right behind the overflow canister. what do these go to? Thanks for ur help!
StylezTA
Car: 2002 Trans Am
ok, well after some more research i found that these 5 wires are what should be connected to the injector resistor box that was cut from my harness. Lovely huh? so thats 2 things cut, maf plug and resistor box. I still do not know what that connector is for however. i am thinking its the plug to the knock sensor. but the knock sensor is one white wire while this plus is a solid white AND black. Let me know if this is the white wire i need to splice the knock sensor into. its in the ca engine harness.
rico05
Car: 1992 RMS13 w/ CA18DET
That plug looks like the one for the stock boost control solenoid.
