cut ecu
josephg15
Car: 1992 240sx
there are like about 10 wires cut from the back of my JDM #62 ecu...is it supposed to be like this...is it beacuse im not going to use these wires or do i need to take back my wiring harness? doe s anyone know where i can find out what the wiring diagram is for the jdm harness (sr20det s13) and what each wire color is used for...please help i am in the process of my swap and want to finish it soon...thanks again
Blown240sx
Car: 1996 240sx
Those wires are most likely not used. They are probably for EGT, Hicus, and other emissions things that were on the original car.
inertiadrft
Car: Do NOT be fool'ed by the low post count, The wise choose silence over Bla Bla Bla...
what are the colors of the wires??? a pic would be helpfull.....
inertiadrft
I hope that info I sent you is helpful to you....good luck!!!
S13240
Missing a the plug that goes up to the dash?
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
well normally when u wire up an SR20 to the S13, there are about 6-7 wires that really matter for getting the car to run. the rest are for of course emission bs and the consult port.
