Cut antenna cable question
junjun0134x
Car: 93 Nissan 240sx
when i got my 93 240sx the radio wouldnt work or be very staticy i later found the antenna cable was cut by sum retard. Well the prob i have is that there are 2 diff cables and i was wonder if there was a way to connect them together or do i have to get a new cable and run it through the car?...heres a couple of pics of da cables
junjun0134x
It must say look but dont touch somewhere cuz i got some views but nobody wants to say anything...if it was a stupid question let me know but answer it to plz...........do I have any takers???? just need sum help
ChuckNC
Car: 1992 240sx hatchback
I had a problem with my antenna cable, too. I was able to solder on an end to fit into the radio, but I found pieces of wire under the carpet and seats that I couldn't find what they were for. I just pulled them out as they were cut on the ends. I would trace them out and see where they go. Use the one that goes all the way to the antenna. If you don't have one, order one that's the right length from the auto parts store and put it in.
Vegascorbin
Car: 1990 240sx dirt track race car
The upper picture doesn't look to be antena cable. It looks more like speaker cable (or "ZIP Line to some).
Antenna cable is generaly a Coax type cable like that shown in the second picture. The inner wire is for the signal and the outer wire keeps the nose from interfering with the signal.
Coax cable also is made to special standards as to impeadance etc. Although possable to splice it is not recomended even for experianced technicians. Purchase a replacement cable and install it. If it is too long just coil the extra out of the way. It is best not to cut it unless you are experianced.
adrianfromthecastle
Car: 1992 Nissan 240sx
Vegascorbin wrote:The upper picture doesn't look to be antena cable. It looks more like speaker cable (or "ZIP Line to some).
the second one is indeed the antenna wire. Most aftermarket antennas require you to cut the original wire anyways.
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
Actually to clear this up.....The factory antenna wire is 2 separate wires, the AM antenna is built into the back windshield and uses the smaller wire, the other wire actually comes from the antenna.How do i know.... i shaved my antenna and pulled all the wiring out.
And to tell you the truth trying to splice shielded wire is a *****.You have to solder the interior wire, then wrap it, then wrap that in the outside shielding braid and make sure that's all solid. then wrap the whole mess again.So your best off probably just running new wire.
Felipe
Car: abcdefghijklm nopqrstuvwxyz `1234567890-= ~!@#$%^&*()_+
if you have the patients, do it.
i did it.... my sht was cut too... had to buy the other end and connect them.
G.L.
adrianfromthecastle
Felipe wrote:if you have the patients, do it.
G.L.
yea mine was cut too.. i just left it as it is... radio in socal sucks anyways.
Felipe
adrians_s13 wrote:yea mine was cut too.. i just left it as it is... radio in socal sucks anyways.
i did it for my...
junjun0134x
Thanx alot i really appreciate the help... My friend says he's really good at reconnecting that so imma stick with that and if it doesnt work out then I get to run a new cable through
Thanx again
