You don't NEED an intercooler to run stock boost. But you will probably want to run super unleaded rather than just the 87 the manual calls for.G-E wrote:Many people chose to turbo the non-turbo block, it has higher compression, which makes it more responsive and generally more powerful, the side effect is you also need an intercooler then...
There's no difference between engines internally aside from pistons
