Neo Xian Wu wrote:now it's good news that i can install a CAI without losing warranty, but what about springs, exhaust, wheels, and body mods? thanks in advance for your answers.
The answer to this is always going to be the same... the dealer has to prove that the modification caused the problem in order to void the warranty.
In almost all cases, a CAI, exhaust, and wheels will be nearly impossible for them to prove causality.
Springs will most likely void your suspension warranty, as they will create a significant change in your suspension (your stock struts will wear out REALLY fast if you don't replace them with aftermarket struts to match the springs).
Body mods... it depends on what you mean by that. Adding a body kit and spoiler won't affect the warranty at all unless you have to drill holes to mount them, in which case they void the anti-perforation warranty. The same warranty will also be voided any time you make a cut into the metal to do anything like a hood scoop, fender flares, louvers, etc.
Honestly, a lot of this goes to common sense. Ask yourself:
Will I have to cut any part of the car (or wiring harnesses) to put it in?Will it increase the amount of heat the car or engine generates?Will it put additional stress on the clutch/TQ converter, brakes, or suspension?Will it require reprogramming the ECU, TCU, or BCM?Will it increase the intake manifold pressure to greater than 1 ATM?
If you answer yes to any of these, it will probably void your warranty. If the answer is no to ALL of these, you're probably fine. Just as a rough guideline, of course. Some dealers are bigger sticklers than others.
And if you want an added measure of security, keep your stock parts handy and put them back on before you take your car in.
The other thing is that a dealer can only void PART of your warranty, not the whole thing. If they CAN prove that, say (this has happened to me before, different car) the stereo you put in is causing an intermittent ground fault in your cluster lights, they can't void your engine's warranty or your transmission's warranty, only your electrical warranty.
Clear as mud?
