Customer highpressure power steering line?
stuckeypcs
Car: 1990 240sx
I came across this on a thread and am very curious what I need to duplicate this? I was on Jegs and saw where I can get the fitting for the steering rack, I was just curious if anyone could tell me what AN Fitting pieces (size/thread/an) I need to connect to the power steering pump like i see here.
Thanks!
**ignore the stupid title, due to my line of work I always type cusotmer when I intend to type custom.**
Modified by stuckeypcs at 1:33 PM 5/2/2007
preludervtec
http://forums.racebread.com/index.php?topic=1568.0
That should tell you all the parts you'll need to make your own customer PS line. I plan on doing the same when i do my SR20 swap.
stuckeypcs
Car: 1990 240sx
preludervtec wrote:http://forums.racebread.com/index.php?topic=1568.0
That's awesome! That's exactly what I was looking for! Thanks alot!
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
I figured out what was necessary when doing my LS1 swap. I used a similar, if not exact fitting to go into the rack (14mm x 1.5 --> -6AN) BUT it leaked.
Problem is that the stock fitting is longer than that Earl's fitting so the o-ring could not seat properly. So, either use the fitting anyways and use some loc-tite or teflon tape and hope for the best or hack off the stock fitting and rig up some other solution (I recommend the Earl's fitting). BTW, loc-tite works great for sealing high pressure stuff, but if you ever need to get it out, better hope you used the blue kind and that you don't end up stripping the aluminum.
kpodj61240
Car: S14 Zenki
I am wondering how to do this for the s14 chasis and sr pump , i believe the link expired. can some one email me [email protected]
P_856
Car: s13
High Pressure:
EAR-130606ERL 6ft of -6AN Power Steering Hose (Blue Hose)
EAR-134606ERL 45degree -6AN Hose Fitting, Steel, Zinc plated
EAR-139106ERL 90degree -6AN Hose Fitting, Steel, Zinc plated
EAR-9919DFJERL -6AN to 16mm x 1.5, AN to Metric fitting adapter, blue
EAR-991954ERL -6AN to 14mm x 1.5, AN to Metric fitting adapter, blue
Comments: You only need about 1.1ft of the power steering hose.
kpodj61240
Car: S14 Zenki
thank you very much! that was quick.
kpodj61240
Car: S14 Zenki
a couple questions, the 16mm and 14mm jam nuts are those restrictors or do i need to add restrictors. I dont know if it even matter how much fluid goes into the rack?? and does this line replace the big metal banjo fitting that bolts on the pump
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Thought you liked not having power steering?
P_856
Car: s13
kpodj61240 wrote:a couple questions, the 16mm and 14mm jam nuts are those restrictors or do i need to add restrictors. I dont know if it even matter how much fluid goes into the rack?? and does this line replace the big metal banjo fitting that bolts on the pump
no need to add anything just those fittings, the fitting replaces the banjo bolt and the one sensor too
