Custom Wheels
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
acarnut
Has anyone upgraded their EX35 with custom 18" wheels and wider tires? If you have, could you share the make and model for both wheels and tires? I called some local shops and so far no one has even heard of the EX, let alone being able to show me some compatible options. I think I like the EX wearing rims with fewer spokes...
rubbersidedown
Car: Infiniti EX35. Black & Chestnut. All options but Tech Pkg. RWD.
Acarnut, any luck? Has anyone else found custom wheels for the EX? As the EX is based in several respects on the G35, has anyone checked to see whether wheels that would fit the G35 would fit the EX? Thanks,
jmess
The 07+ G35 has the same offset and bolt pattern but I haven't been able to find out if the hub diameter is the same size. I would think it should be the same.
jmess
Looks like there are a lot of potential donors for snow tire wheels.
Width Offset Hub Dia Bolt PatternEX-35 17x7.5 45MM ?? 5x114.3EX-35 18x8 47MM 5x114.3 06 G35 17x7 45MM ?? 5x114.3 18x7.5 45MM 5x114.306 G35C all 30-33 5x114.3
07+ G35 17x7.5 45MM 5x114.3 Sport F 18x7.5 45MM 5x114.3 Sport R 18x8.5 50MM 5x114.3
08 G37 18x8 43MM 5x114.3 Sport F 19x8.5 43MM 5x114.3 Sport R 19x9 45MM 5x114.3 07 FX-35 18x8 40MM 5x114.3 20x8 40MM 5x114.307 Murano 18x7.5 35MM 5x114.309 Murano 18x7.5 50MM 5x114.3 20x7.5 50MM 5x114.3
rubbersidedown
To All - Please post photos of your EX if you have mounted custom wheels. I'd like to see actual photos as opposed to computer-generated images to see what direction I might go. Thanks,
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
jmess wrote:The 07+ G35 has the same offset and bolt pattern but I haven't been able to find out if the hub diameter is the same size. I would think it should be the same.
Hub diameter should be the same. All Nissan 5 lug cars use the same lug pattern and hub diameter. Wheels that fit other RWD Infinitis will fit the EX.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
all 5-lug nissans in the last 20 years have a 66.1mm hub bore.
anyone ditching their 7-spoke 17's let me know. I'll buy 'em.
rubbersidedown
3Q Jay,
Please contact me directly to discuss further. I have the 17's on the EX, that I am thinking of replacing. I like the style of the 17's better than that of the 18's, so I am thinking of going in the direction of a custom 18. (BTW - does the photo on the forum homepage strike anyone as an 18 inch version of the 17's?)
Please email me: [email protected]. Thanks,
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Edley- email sent.
datura2000
Car: 98 Disco series1
EX and the G sedan (awd) have interchangeable wheels. 17x7.5 or 18x7.5 for the G..... 17x7.5 or 18x8 for the EX. Offset is identical.
G35 Sport (rwd) sedan has 18x7.5 F and 18x8.5 R. They should still fit the EX.
So....find aftermarket wheels that fit the G and they should be just fine on the EX. Post some pictures of your wheel choice....we'd like to see! 19's perhaps???
nghivdo
Car: 2008 Infiniti EX35 AWD Journey, Premium, Luxe Style, NAV, Black Obsidian, Graphite Leather
I'm considering 19's or even 20's... can't decide between brand, style....black with polished lip, or the new "hyper-black"(really a platinum or dark silver) for color...on my black EX. Has anyone upgraded? Pictures? How's the ride quality? I feel that the EX could definitely use wider, stickier rubber when I really push it into corners! Any input is greatly appreciated!
Modified by nghivdo at 12:15 AM 6/6/2008
st_donjuan
Car: Mercedes S500-4matic 2004, Infiniti EX35 2008
I put 20's on my Ex (white).Alba AL717 20x8.5 +42 with 245/40/20.They work fine with my EX.I will post some pictures soon.
nghivdo
st_donjuan wrote:I put 20's on my Ex (white).Alba AL717 20x8.5 +42 with 245/40/20.They work fine with my EX.I will post some pictures soon.
Yes, please do post pictures! Many angles/views would be nice. What tires did you opt for? How's the ride/handling? Are you happy with your choices?
Modified by nghivdo at 12:13 AM 7/11/2008
Fishman1421
Car: Infiniti EX35 AWD Journey - Black Obsidian w/ Graphite Leather/ Black Lacquer with Aluminum
I have decided that I most likely will get my stock rims dipped so as they are chrome to match the exterior of the car. I think that this will provide a stylish as well as custom look.
nghivdo
Fishman1421 wrote:I have decided that I most likely will get my stock rims dipped so as they are chrome to match the exterior of the car. I think that this will provide a stylish as well as custom look.
It'd be great if you could post the weight of one rim before, as well as after, the dip. I'm curious as to just how much weight it adds. I'm assuming you have the 18" alloys? Oh, & of course pics would be nice!
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
