Custom Wheel Help Please...
QuickerThanU
Car: 98,95,94,89 Nissan 240sx
Im having a set of custom wheels made that are 19x8 front and 19x10 rear. I have an s14 on silk road with 50mm wide body fenders in the rear. I want the biggest lip possible so i need to know the lowest offset i can go on the rear and be safe. Any help is much appreciated. I also searched and best i got was roll the fenders which i cant do or need to do.
onosqv
Car: '92 240sx Vert
as low as they'll make it... you can always have the over fenders molded to fit (i.e. 50mm is a soft number, not absolute).
If you already molded the rear fenders, just take out a measuring tape & see how much further you can go out.
W/ 50mm fenders, you should be able to run into the negative offsets easily.
