custom turbo questions
spooler
I am helping a friend with a custom turbo setup on his 240SX. I have a few questions regarding doing a custom setup with a T3/T4 turbo.
1. What manifold do you guys recommend using?
2. Where do you get the oil feed from?
3. Where should I drill the oil pan for the oil return line?
4. How much boost can I run without an intercooler? About 6?
5. What adjustments do you make to the timing for the turbo?
6. I am planning on using a AFPR to rise fuel pressure under boost. Any objections for low boost setup?
Thanks for the help.:)
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
revhard, but stress releive it and port the thing out a bit
'T' off the oil pressure sender
right bellow the turbo, run it as straight and as high into the pan as possible
try 5, 6 might be pushing it
pull out like 1 or 2 degree's at most, it should be allright at low boost though
running 90psi of rail pressure isn't exactly safe, but it will work for a short term fix, it is just a very crude system for controlling fuel.
spooler
Quote »2. Where do you get the oil feed from?[/quote]
Quote »'T' off the oil pressure sender[/quote]
Do you know where I can pick up this part? (The T fitting)
Thanks:D
Movingviolation240
spooler wrote:Do you know where I can pick up this part? (The T fitting)
Thanks:D
it's just a brass NPT fitting you can get at any NAPA
