Athikerguy4life »
https://forums.nicoclub.com/athikerguy4life-u182079.html
Thu Apr 14, 2011 6:16 am
So after doing some research on here and looking at some local stores I have decided to build my own custom box for my V. I have the 1.8 Sedan, and being the S model, it is not wired for the stock sub. Most of the boxes out there are way to big for the trunk of my car since I use it quite often to haul around gear, plus the tiny little floor panel probably can't hold up much more than 50 pounds..
Here is my plan: I want to frame out the trunk with 2x3's. This will give me a stable platform to put my new box on. Once I have the 2x3's down, I'll cut some mdf to cover the entire floor of the trunk. The sub box will be placed right against the back of the rear seat. One piece of mdf will cover the top 1/3 of the trunk (closest to the seat) and another sheet will cover the bottom 2/3s of the trunk. The larger sheet will have either a cutout or doors that can be lifted out completely or opened up so that I will still have access to the spare tire and what not. It's probably going to be a sealed enclosure and I'm going to cover the whole shabang with black carpet (to match my interior) And I'm going to add some sound dampening in the space thats going to be provided by the 2x3 frame. I want to make sure that I will be able to return the whole thing to stock if I ever decide to sell it. I'm also thinking of adding some led's or something and running them off the trunk light wire so that they only come on when I open the trunk.
This will be my first box build and I will be taking pictures to post as I go. Hopefully will be starting in the next couple weeks. The sub is a 12" 1000 watt rms. Haven't decided if I want to run 2 or 1, but proably just gonna stick with one.
So, anyone have any ideas or input?
Sealed vs Ported?
Cheap options for dynamat?
