Silvia2b »
https://forums.nicoclub.com/silvia2b-u2470.html
Thu Dec 22, 2005 10:07 am
Or you can buy them in bulk from Select Products. They use their router and bits, so yours don't get dull cutting through .75-1.0'' of MDF. Plus this can be very hard on the motor, depending how good the router is. Even the 3/4HP models we use only last 2-3years tops. Select also sells plexi rings and other items like aluminum mesh.
The device that you attach to a router to cut a circle is sometimes called a "perfect circle" the type of bit you need is a "plunge bit". The bit doesn't have a berring on it like most other router bits. The shank is usually much narrower than the end the router attaches to. Max dia. of the cutting part is like 3/8 or less(unless you have a 1/4" router), with two opposing blades, like 1-1.5" long, with total length of less than 3".
