deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Thu Dec 15, 2005 3:39 pm
What kind of custom shims are you needing? Are you running a regrind cam? You need to be careful with a heavy regrind in the ka24de valvetrain, the bucket tops cannot hold a thicker shim as well as the original. Even though a regrind cam with a reduced base circle has a smaller lobe overall, with the thicker shim combined these setup can be as prone to throw shims as a a large (standard) basecircle cam with large lift. With the stock bucket size, you are limited to about .450" lift with standard basecircle before you will start throwing shims at high rpm. With a regrind and thicker shims, about the same.
You can use select volvo and bmw motorcycle flat tappet shims to custom fit to the ka24de. If your out price searching and looking at any sort of a new retailer price, your not going to find them cheap. BMw offered some bmw mechanic shim sets with about 10 each of 10 different dimensions, these are about .020" thicker than a ka24de shim on average and have been used with custom regrind setups. Sometimes you can run across these kits used.
