240nspec wrote:Hey guys, just wanted to say thanks for everything. Once I get back in the shop, ill give r' a try. and qat thanks a bunch for the taper dimensions,
Much appreciated,
240nspec
No problem. Glad to help.
s73 wrote:i have some honda knobs that is m10-1.5...you think i can re-tap the threads to 1.25? or u guys think there may not be enough meat on the threads?
For it to be strong enough for me to trust with a load, it wouldn't come close to having enough meat to retap at a different pitch but the same diameter. That said, we're talking about a shift knob, and a lot of manufacturers don't even thread the knobs, they just let the shifter threads cut into the nylon insert in the knob. Considering that, I think you could get away with cutting 1.25 pitch threads in the knob, and if it did strip totally out, either fill it with JB weld and hit it again, or just bore it out some more and glue something like a 9mm ID nylon insert in.
