Custom Rims - TPMS on a 2007 Infiniti M35X
mjohnson
Car: m35x
I purchased a set of Verde rims for my 2007 Infiniti M35X. I was informed that the wheels including the TPMS would fit with no problem. I had the original tires removed and placed on the new Verde's. The tire tech informed me that the TPMS values would not work because there was a little play where the rubber grommet contacted the rim. Then he showed me how snug the TPMS valve fit in the stock rim. I know some of you have replaced the orignial rims and used the TPMS valve did you replace the grommet or tighten down the nut for the valve? Did your wheels leak air? (I had regular tire valves put in)
I was going to post a picture of the wheels but I don't see how I would upload the picture
jEzTeR
Car: '07 Infiniti FX35
'02 Nissan Altima SE 3.5
'93 Nissan 240SX Hatch
I took mine out. There are a lot of arguments about how accurate the TPMS can be. The best thing to do is get a good hand held unit and check your air every few days or so.
As for the pics, you will need to find a web based site to host the pics on and then post them here. What color is your car?
CakeDaddy
Car: Y34,Pathfinder SE, Mercedes CLK500AMG Sport Pkg & A Fleet of Premium Avis Rental Cars
jEzTeR wrote:I took mine out.
hmmm, really! do you get any crazy beeps,readings, or any annoying icon on you display or gauges?
cremecreme
Car: 2003 m45
i just put mine aftermarket wheels on this weekend and no TPMS and no beeps or anything....just blank under tire pressure...all good to me!!!
jEzTeR
Yeah just ** PSI.
Tmoney
Car: M35 Sport
Here is quick fix for those with aftermarket rims with no TPMS. You can simply drill and mount the TPMS on the inside of the rim opposite to the valve stem. I did this with my Rays Lexion Type 203. I have included a few pics. Let me know if you need more info.
szh
Car: 2018 Tesla Model 3.
Now that is an excellent idea! As long as the seal for it is good, it should work out very nicely.
Thanks for the pictures!
Z
P.S. I would still recommend a quality tire pressure gauge and a weekly check and pump up (tire cold, in the garage, early morning, before you drive it one inch, before the sun gets a chance to warm the tire, etc.)
auditech10
Car: 03 M45
WHY oh why would you drill holes into your riims to do that??? Why not just do it the right way, you have to take the wheels off anyway.
Tony407
Car: 2007 Diamond Graphite Infiniti M45 Sport
There is a little orange flat tire symbol on the left side of the dash that blinks when I start the car and then stays lit after a few moments when I have my winter tires on w/o the TPMS.
Question: I have the OEM wheels back on the car and now I only get tire pressure readings on the two right tires, neither left tire is showing a reading. Is there something special I need to do to get them working again?
Tony
szh
auditech10 wrote:WHY oh why would you drill holes into your riims to do that??? Why not just do it the right way, you have to take the wheels off anyway.
It is just for the TPMS sensors - you do not need to continually access this connector. The tire still has another place on the outside (original location on the rim) to do the actual air filling, etc.
Z
Tmoney
Car: M35 Sport
Tony407 wrote:There is a little orange flat tire symbol on the left side of the dash that blinks when I start the car and then stays lit after a few moments when I have my winter tires on w/o the TPMS.
Tony
It should actually reset within 50 miles or so, if not there is a problem.
