lightsout »
https://forums.nicoclub.com/lightsout-u71638.html
Mon Mar 24, 2008 8:59 am
to keep the paint from chipping you MUST use PPG Epoxy Primer:DP40(white)DP48(light grey)DP50(darker grey)DP60(blue)DP90(blackthe DP Epoxy Primers need to be painted in suuuuper thin layers with low air speed throught the paint gun. 5 very thin coats of DP, then one good coat just before you Shoot the paint. When you shoot the paint, use the same steps as the DP primer(5 very thin coats, 1-2 good coats at the end)...following these steps will prevent your dash from chipping or cracking. Most paints today dont crack b/c they have become more and more flexible. I used a Single Stage PPG DCC paint...it is a paint that has the clear coat built in to the formula. You can use a 2 Stage paint also. 2 Stage paints are applied by first shooting the color, then layering the clear separately. More experience is needed to used 2 Stage paints b/c the painter must have great vision to watch for sagging in the clear coat. Sagging and improper paint reducing can lead to that nasty orange peal look in your clear coat.
i would not recommend using ANY rattle can products if you want the paint to last, and not chip.
as far as selling the extra parts...right now i don't plan on selling them b/c i would like to have the security of having a back up....BUT i will for sure put up a post if I change my mind
anyone know what the bulb code is for this bulb?? Its the bulb that shines from under the AC controls onto the coin tray&hazard button. I want to replace it with an LED...but don't know what kind of bulb it is
Modified by lightsout at 12:54 PM 3/24/2008
