I'm just used to the exhaust piping used on my old race car. Minimal bends, with the most direct route to the tailpipe outlet.MadOx75 wrote:It's not really a "maze" of piping, just the one pipe has to loop back around the muffler, but I know what you mean...lol.
There is a tow hook on the RH side that can be removed. There is also an evaporative emissions canister... which you cannot remove.If I remember correctly, and I think a few of the pics show it, there's something on the underside of the car on the passenger side that is right in the way of where an Altima style muffler would be mounted.
At least muffler is not huge like on that saturn:philipa_240sx wrote:I'm just used to the exhaust piping used on my old race car. Minimal bends, with the most direct route to the tailpipe outlet.
Fortunately you left the stock resonator in place. Had you removed it, the droning would be even more unbearable.MadOx75 wrote:It sounds really good outside the Rogue, but at low RPMs its a bit "buzzy" inside the car. I'm going to have to get used to it.
Honestly, I have no idea. I'm sure it probably did, because it definitely breaths a lot better now with that Magnaflow muffler than it did with the huge stock muffler. Apparently Nissan uses some pretty restrictive exhaust on these motors, as evidenced by this post - http://www.nissanclub.com/forums/2002-2 ... post346014pawprint wrote:Did it increase your horsepower? I remember the Cadillac Northstar engine had 300hp with dual exhaust versus 290hp without. Of course, that was a few years ago, I think almost every car over 30K has dual exhaust standard now regardless of increasing horsepower.
MadOx75,Apparently Nissan uses some pretty restrictive exhaust on these motors, as evidenced by this post
That would likely go a long way to helping the issue. But ultimately any straight through muffler like the one you chose is going to sound very loud.MadOx75 wrote:The inside is an entirely different story. Without having a true trunk area to contain the sound coming from the rear of the vehicle, combined with the way the CVT holds its "gears", the sound is downright annoying at times inside the car. I probably should have known that it would be like that, because every external sound that comes from back there seems to be amplified - road dirt hitting it, rain water splashing it... I'm planning on taking two courses of action to correct the sound issue. First, I'm going to take it back to the place I had the work done and have them add an additional resonator (the stock one was never removed) in hopes that it quiets it down a bit. Second, I'm going to take apart the area by the spare tire and put some Dynamat or Hushmat down on the entire section. Hopefully these two things will quiet it down some.
