bone_stock_240 »
https://forums.nicoclub.com/bone-stock-240-u55171.html
Tue Aug 21, 2007 12:53 pm
No, you haven't searched.
The manifolds are all different between the KA24E, KA24DE and SR20DET. You do not need a pump, but I am not sure of the routing of the oil lines. You do not "bolt" it to your oil pan. You have to drill it, and then attach a fitting.
What needs to be done before the IC piping is a lot of research on your part. Start by reading through the stickies in the KA-T forum, and when you are done that, you can ask alot more educated and specific questions.
