Custom intake
D_roc
Car: 2001 Maxima 20th aniv edition
i want to to a intake bad but have couple questions first i'm going to run the filter all the way behind the front bumper so what can i do to prevent it from sucking up water, and will it make any difference in power id i used the stock air box filter and also add a pipe wiht a k & n filter to the same place (behing the bumper)
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I'd probably relocate the battery and run it down in that corner. You should be able to get good fresh air supply without having to worry about water. Remember there's a lot of plastic cladding along the underside of the engine bay that does a good job of keeping water out. Heck, if the alternator can survive down there, so can your air filter.
D_roc
true, what about the 2 sensors that hooked to the air box, here should i hook them on the intake i would have to drill a couple of holes? for MAF and the other sensor in the front
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
2 filters = restriction in air flow. check out a company called spectre - they make a bunch of diferent kinds of elbows, pipes etc so you can piece together an intake of your design. if you don't want to suck up water...don't drive through deep puddles pulling from the bumper but if the pipe bends up at 90 degrees you won't get a lot of water in there. best thing to do is to run not an aluminum but rubber or plastic pipe from the stock airbox with a k&n down to the bumper and put a scoop on at that end.
allensteiner
check them out, it's for 3800 gm's but the tubing would be right - just slap a scoop at the end to ram air in: http://intense-racing.com/Merc...ction
allensteiner
just thought about something you might like. the gm 3800 series 2 supercharged was pushing only 9psi boost. i thought about putting one on my max in the future, the only thing would be finding a machine shop that would customise the LIM for a direct bolt on. i thought about getting a bigger pulley on it to run 5psi at WOT - no need to upgrade injectors or anything. you should look into that. i think the blower on those was from eaton and you can pick one up at a junkyard from a wrecked bonneville for about $200 - a lot cheaper than turbo and less work.
D_roc
custom fitting something like that will cost $$$$$ and i live in cape cod so its wicked hard to find a place to find a machine shop, guess i'll just go with a CAI for now the duct think is easy but mad ugly idk yes but to do anything i have to wait until my next paycheck, i really like the sound a CAI make but the main concern is water sucking up through it
snwbrdr435
Car: 85 VW Westfalia, CBR F4i, SV650s, 1988 Honda Hawk(race)
If you dont hook up you maf sensor the car isnt going to run. Also you are going to need to put a breather tube on your intake so that you can connect the three breathing tubes to it. I duno if that made sense but whatever im going out on the bike to the beach
D_roc
i just took a look and i thing i can just take the air box out and leave the MAP as is they sell some adapters for it, and i did not see any breather horses going from it, also which is better chrome or polished aluminum
tigersharkdude
Car: 1999 Nissan Maxima
check out mine, on my cardomain link below
audtatious
D_roc wrote: i really like the sound a CAI make but the main concern is water sucking up through it
You can always get a bypass valve
http://www.tirerack.com/intake...e.jsp
tigersharkdude
heres minei know have a kandn air filter on there
D_roc
so did you have to cut the metal to make a hole so the filter can go through, looks pretty sweet
johnnyd6404
Car: 2004 G35 Coupe 6MT 2k2 Maxima SE(sold) 2005 Altima 2.5S
Here is a link for a how to turn an injen cai/wai into a true cai. The picts are gone but it will give you the gist of how to do it.
http://forums.nycmaximas.org/s...25714
p.s you need to sign up to be a member to see the thread but it is worth the couple minutes it takes.
allensteiner
what if...you decided to sacrifice your ac and got a used turbo, got rid of the exhaust turbine housing, replaced the turbine with a pulley, mounted it in the ac spot and called it a custom supercharger? no need for the blow off valve etc. just throwing it out there...
D_roc
i need my ac man. its brutal during summer in here
D_roc
what is this sensor is it the temperature sensor and also is it ok to drill a hole on a short ram intake and out it there because its juat a piece of plastic and can it break off and get sucked in the engine?
allensteiner
piping from spectre comes with holes for sensors, hose fitting etc. no need for drilling and that is the air temp sensor.
