Greek.intuit wrote:Explain to me then why I'm noticing better gas mileage and better performance using better gas. It not only doesn't leave as many deposits, but there is a noticeable difference on long trips or high revs.
I'd like to point to Jemdawg's response as part of my response. You have a small sample. With that said, there could be any number of factors that caused you to get a higher fuel economy. Driving slightly slower, less wind, warmer day, less hills, less traffic, less turns, etc. I once averaged 55 mpg on 87 octane in my V on one leg of my cross country trip at 74mph. How? Beats me. I know the math is correct because it was checked by 4 people (one of which was the station manager) But it didn't last and after the next 13 fillups, I only averaged 34 mpg.
Furthermore, I'd invite you to further research the definition of "octane" to find out how the different levels work. There's no difference in the quality of gas between octane 85 to 103. I find it hilarious that people think that 87 is this dirty gas full of gunk and 93 is so much cleaner. 93 will leave no less deposits in the engine than 85 unless it's specifically stated that the higher octane contains more detergents. Octane is all about volatility.
As far as Top Tier companies, there are specific requirements. Granted companies are allowed to determine how much and what types of detergents to add to the gas, but all must conform the the standard at a minimum. This standard supersedes both government and common industry standards for detergent requirements. All grades of gas must meet the detergent quantity standard.
As far as the deposits, you have to understand how they form. They are not caused by humid air . Deposits on the fuel injectors are formed only at one point, when you shut the engine off. When you shut the engine off, and there's no more coolant circulating, the engine continues to heat up. It's also known as soaking. When this happens, there's a trace amount of gas left on the tip of the FI. Most of the gas will evaporate, but a trace amount will bake on. This is where deposits begin. Only after an accumulation of the deposits (far greater than 350 - 400 miles) will it become a build up that affects performance.
Lastly, most modern fuel injectors installed in cars are a totally different type of than those of yesteryear. The newer design of fuel injectors are designed to resist the problem of deposit build up. Doesn't mean it's not going to happen, but it should happen as quickly as older cars. Using a better fuel (top tier) will keep the FI's cleaner longer also. If you don't have anything to clean, why clean? You will have spent all this extra money at the end of the year and your FIs will be just as clean as every one else's. If I'm wrong, I'm wrong. I won't be ashamed to admit it. Education is the key.
